Batfish
Batfish's Avatar
08.20.2005, 08:14 PM
Whew! A few questions since my last post, heh :)
First - I did loctite the pinion after losing the first one :)
Second - it's not really a specific screw/bolt that comes loose, it's really my poor design skills that do it. Once I have a better-designed mount it'll do fine. I'm going to be buying another Jato chassis from ebay soon so I have a backup when I drill the current one to death.
Third - the Nomadio Sensor is, for lack of a better description, freakin' awesome :D
Price difference is pretty interesting when you consider everything you get, too. I did a price comparison on rcuniverse in the Sensor thread a while ago. A similar high-end radio with add-ons to make it nearly as feature-rich as the Sensor would run about $700, while the Sensor will sell for $520.
In comparison to the Eagletree system, you'd need the Seagull system to get live data like the Sensor and even then it doesn't give you tactile feedback like the Sensor. The Sensor can vibrate and/or play sound files when an alert is triggered.
The one thing the Eagletree has over the current Sensor configuration is recording of data for later viewing on a computer. A future software update from Nomadio will allow the Sensor to record live to a computer via USB. Granted, carrying a computer with you while driving would be a pain, but it would only be used during practice to gather data and adjust for actual racing.
Sensor can work with up to 4 temperature sensors. There are two ports for temp sensors and each is capable of two sensors. Still waiting for Nomadio to explain how to wire them (and, for that matter, actually sell them seperately) to work on the two ports. I currently have the temp sensor held onto my ESC via ziptie. I figured I'd keep it on the more expensive component while I only have one :)
I love the feel of the Sensor and have become very accustomed to being able to see my battery voltage and temperatures at any time. The only thing I'd change at this point is the springs in the trigger and steering. I'm used to the steering one, but the trigger is still stiff for me. I'll get used to it, I'm sure.
The Sensor is a software-based PC peripheral, which means you should never have to send it back to Nomadio for updates. You just download them to your PC and install through the USB port. You update both the radio and the transceiver this way.
Fourth - I have had zero interference with the Sensor. Since it's DSS I can also turn it on in the pits with no worry about affecting anyone else. At my local track it means I can practice on another track while racing is going on (if I want to).
You can see Nomadio's Sensor support forum here: http://support.nomadio.net
and their regular website at
http://www.nomadio.net
Lastly, I think it will end up being worthwhile for me to have purchased the Sensor since all of my vehicles at this point are "project" vehicles, which means I never know if what I've done is going to work right until I try it. That means that if I gear my vehicle wrong and my speed controller jumps right to 150F I'll know the second it happens and I can stop throttle right then and there. This can definitely save on equipment. I'm sure everyone who already has a $300 radio setup and has fried a $200 (or more) speed controller wishes they had a way to know it was going to fry before it happened. That's how I feel it'll help pay for itself in the long run. Now Nomadio needs to come out with their second-gen transceiver so I can get them in all of my vehicles.
Sidenote to Mike - if we had the Sensor reading the temps on the E-Revo motor we might not have blown up that 10L at Monster Madness :D
There's a nice long post for you to digest. Let me know if you have any questions :)
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
