BlackedOutREVO
12.24.2007, 01:04 AM
Originally Posted by GO-RIDE.com View Post
I've been thinking of turning up the throttle center position until the truck creeps forward even at zero throttle. This should help when coasting into a turn. I've heard of an esc that allows you to do this but has a sensor override so that when the car does come to a stop under braking it will allow the car to go to true nuetral.
Id just put the throttle trim up so it coast's more, but not enough to actually go when your not on throttle
