12.24.2007, 02:21 AM
Not sure if the motor will be any better. Does the stock motor have a 2mm or 2.3mm shaft? It is a 280 size, and I have run a 280 l can feigao in my mini quake. The motor you picked out is for a mini t or rc18t. May be too high kv for decent power or temps. You will have to re-gear. Give it a try, but I am sure that you will need a longer can motor, the increased torque will do wonders for the low end on the truck.
