Originally posted by crazyjr
Hey Batfish. did you think about making a motor plate off the gearbox? thats how i'm doing mine. the only problem i had was the pinion wouldn't reach, so i took an old associated slipper clutch and ground out the center and the bushing to fit the shaft and used the traxxas spring and nut. Now i can run any 32 pitch gear for the rc10gt, even 48 pitch.
Now that sounds promising. Do you have any pictures you can share?
