squeeforever
squeeforever's Avatar
12.25.2007, 04:47 PM
the 7xl is too high of a kv and will have serious heat issues. www.unitedhobbies.com has a 9xl for $47. best price there is. here os a link
.http://www.hobbycity.com/hobbycity/s...idProduct=4880
also make sure you get this system quickly before your lipo gets old and wont preform as good as it should.
the 8xl would have slightly higher top speed, the 9xl would have slightly better accel, lower temps, and batter runtime.
Not true on both accounts. A 7XL, geared appropriately will be fine. You'll lose some runtime though. Only advantage to going with a 8XL will be having lower temps and a wider range of gearing, combination with a little longer runtime. There is NO WAY a 8XL can get faster unless its geared to the moon and gets overly hot. Acceleration will be NOT be better. Also, Lipo's will always perform good...The shelf life is years...Where did you hear that??
