sikeston34m
sikeston34m's Avatar
12.25.2007, 07:51 PM
Originally Posted by VWT4 View Post
I finally converted my MT2 to direct drive system.
The motor is an outrunner 1050Kv, 175gr, 5mm shaft and the ESc a MM.
It works great with two 3S 2500mA lipos or 4S A123.
CVDs are T-maxx MIPs for 5mm shafts.
Hope you like it.
Wow, very nice conversion!
If you got the MM to work well enough, you're going to love the Quark. I didn't have much luck with the MM.
When you install the Quark, set it to "outrunner", starting power high. In the battery section of the setup, either go with Lipoly High, or manual setup, then put the cell cutout to 3.0 volts or so.
Very Nice!
