12.25.2007, 08:01 PM
Originally Posted by mac View Post
lincpimp thanx for info i have a rc8 with the little 8000 mamba esc and motor and its out of control.so that will b best set up what other ideas do u have by chance?and how do u disable mm internal bec and is that safe.
To disable the internal bec just remove the red wire on the end of the harness that plugs into the receiver. You can also use a std 5cell receiver pack, but the cc bec is only 22bucks and never needs charging!
The mamba max esc is a great esc, especially the price! Combined with the clutch setup, 2 speed and mech brakes it will operate with low temps and great reliability! This is most likely the best cost per performance setup a beginner can buy, plus it works!
