08.21.2005, 09:08 AM
If the handling was loose, I would start with heavier shock oil and a lower ride height(maybe-arms level works in most cases). A stiff servo saver and a strong steering servo could also be part of the trouble. Light diff oil (especially in the rear) will help make it easy to drive on the loose stuff as well(if you have this tuning option).
