Thread: Ammo in a revo?
Ammo in a revo?
Revracer
Revracer's Avatar
Ammo in a revo? - 12.26.2007, 06:27 PM
how would the Great Planes Ammo 36-56-1800 do in a revo with a mamba max and twin 2s packs(4s). seems to be rated a lot like the feigao 9l... heres the specs on it
Motor Diameter: 1.42" (36mm)
Motor Length: 2.2" (56mm)
Shaft Diameter: .197" (5mm)
Shaft Length: .591" (15mm)
kV Rating: 1800 rpm/V
Weight: 10oz (283g)
Input Voltage: 14.8-22.2V
Max. Constant Current: 50A
Max. Surge Current: 90A
Max. Constant Watts: 1110W
No Load Current: 1.9A
its the 540 size motor and takes no less than 14.4V, so on 4s do you think it would run it good? i have standard gearing with the close ratio and will be using the tekno conversion
