12.27.2007, 05:28 PM
It is somewhat on the small side- about S~L can sized. Check the gearing calculator for speeds you can expect, but I suspect if you gear it speed it will run very warm and not give very much torque- just too small. Better off with an 8XL on 4s & MM esc...
