cemetery gates
12.28.2007, 03:03 PM
Originally Posted by GriffinRU View Post
If you do not want to use slave configuration, then it would be a little bit painful. Old generation Feigao motors, with thinner end cap would be almost impossible, unless you made a custom end-cap. Then you need to add sensors, i.e custom pcb with hall sensors... If you can do all this, then yes it is possible. Otherwise use slave configuration or order from Feigao sensored version.
Ok, thanks. I thought it might be possible to remove the sensor/endcap from the HV-maxx motor, it looks like its much more trouble than its worth.
Thanks again!
Bye
