myndseye
myndseye's Avatar
12.28.2007, 04:35 PM
No modifications that involved anything worth mentioning. As you can see, I opted for the single speed setup. I had a Kanai 2 buggy lying around to rob parts from, so I just used the center diff from it. I replaced the steel 46 tooth gear that was on it with a 44 plastic one I got from Monster as well, and it all just bolted right up. Maybe there was a difference in length for the front center shaft, but as I was getting the CVD's from the K2, so there were no problems. The slots for the screws in the mount had to be dremeled out a bit to accomodate the thicker mounting screws that the 1527 needed, but that was nothing major.
