Originally Posted by squeeforever
You'll need those, shims (naturally), as well as these (lowers the center diff), this (different front the CR to the CRT, because the CRT has the larger spur which would hit the buggy one), and a Kyosho spur, which I assume you have already. If your using Mikes mount, your gonna have to get the buggy one to lower the center diff. Now, some of this is based on the fact that its brushless, which I would assume it is...
Yes it's BRUSHELESS. I would be using mikes buggy mount . I forgot about the shims, thank's for the reminder
. The plastic mount i new i would need one & the diff plate i may just make one & incorperate a ESC mount into itjust like dans.
