12.30.2007, 07:56 PM
If you stick with the 2 speed and mech brakes you should be fine. Keep the top speed to around 35mph and that will help the load on the motor. I would gear it 17/38 with that motor, and get the rcm heat sink, it will help with the temps, and keep the motor together. Make sure that you keep an eye on the temps during the first few runs to see if the gearing will work.
