sikeston34m
sikeston34m's Avatar
12.30.2007, 11:06 PM
hats cool, thought that you were talking about the 4130 motor you had in there before, I need to re-read the thread, my memory sucks! How is the new emaxx coming along? Are you going to do a custom wind, or the motor we were discussing? I have to finish my other rc projects before I start on the new emaxx!
I'm thinking this is about a 500kv motor that's capable of over 100amps. The Croco site stated that a single strand of 18awg would max out around 50amps. It stated that was about all 18awg 200C rated wire could handle. This custom wind has 6 strands of 22awg 200C wire. (note: most manufacturers use 30awg wire)
I went with the 4130 because of the longer magnets and the longer stator. I knew it would make alot more torque. The wye wind seems to give alot better EMF back to the ESC. I believe this is why it is working better.
My Tower order will be here either tomorrow or Wednesday. In it is a 2826/10 for the E maxx. I'll probably set it up and play around with it until I can get the 2 speed kit. I need another Quark ESC though.
I really think it will work GREAT with the factory wind, but we'll see. I know it's not really gonna rock until I get the 2 speed kit.
I think I have enough gears here to get the most out of the factory wind in 1st gear. Get the setup right where it doesn't cog at all with 1st gear, but tops out the highest. Then I KNOW 2nd gear will just give a huge top speed boost.
It should Rock and Roll.
