08.22.2005, 01:27 PM
Hi MT enthusiast!
Welcome to the forum! i saw your name a few times on the new member list.. nice find..!
to answer your questions as accurate as i can;
1) the 9L is good for 14 cells, on 16, the 10L is the best option of the two mentioned motors, but i would reccomend a 7XL, on both 14 and 16 cells. you even can take it out for a spin on 18 cells.
2)Hard to tell..the CF is a bit lighter, aluminum will give and bent, CF will snap on a big crash. Though i never seen any pictures of a broken CF chassis. (it is TOUGH) my sugestion is, choose what you like to see... :) the motormount can be used as speedoholder, bu you need to fabricate something that can be mounted to that holder.. So you are better of making something that mounts the controller directly to the motorplate or to the chassis.
3) the MGM is a great controller, the service is good as well the 9920 is very good as well.. the MGM has got more adjustment options.. one nice feature is it's lipoly cutt-off voltage..
4) if placed in the weak voltage circuit, you can use it.. If you use a Ubec it's not needed..
5)depends on the motor/ no of cells.. 9L/10L 7XL 14, 16 cells.. gear it to go about low 40's for bashing and you're good to go.. (in 2nd speed)
6)Mike can get you the dogbone you need.. (including the cups)
3)
