Thread
Why do things always go wrong while bashing...
B15
01.02.2008, 02:07 AM
Do you have a flat spot ground on the shaft for the pinion set screw? I thought this same thing happened to me, but it turned out the pinion set screw had cut into the shaft all the way around, allowing it to slip.
B15
