Glad you guys like it as much as i do
@pb4ugo
Normally i run 9-13 minutes per charge. On this run i pushed the truggy as hard as i could and was really surprised that i used more than 20A average (which corresponds to 570 Watt average). On my preceding 60 runs my average current draw hovered between 10-15A. It really depends on how much grip you have and how hard you run it.
This for example is a more typical graph of my runs. If you compare the
Watt,
Amp and
RPM distribution of this run (nr. 38) with the above linked graph, you will see that on my video run almost 50% of the runtime the motor RPM was between 25000-45000rpm and on run 38 i drove the motor only at 25% in the same rpm range. More full speed driving costs more energy, which reduces runtime (nothing new there
