Thread: SS5800 E-Maxx
JimmyT
08.22.2005, 07:22 PM
Originally posted by dabid
Take the SS out of the Maxx, it shouldn't have been there in the first place.
Originally posted by Dafni
This motor has no business in a Maxx, IMO.
Originally posted by MetalMan
I am suprised that the SS5800 even ran!
Originally posted by Serum
i would strongly suggest to take the novak out of the maxx and put it back into your pede!
Thanks for the feedback but wow, :eek: I didn’t think the performance was that bad! In fact, if I hadn’t of teased myself with the zipp of the 7-cell set-up (then made custom 3+4 saddle packs to accommodate it :L: ), I wouldn’t be too unhappy with it as a slow-basher/crawler unit – it never thermal’d on 6-cells and second gear was tolerable. In first, at 16/66 with either the 6 or 7-cell set-ups, it can toss itself on its roof with no effort – something my 2.5 never did reliably because of the spool-up in the tranny and clutch.. and tuning! ;)
Go 12 or more cells, and get yourself a Sensorless combo from Mike. (for example the MGM 16o amp ESC or Warrior 9920, and a Feigao 9L or 7XL motor)
The minimum number of cells for a Maxx is usually 12 cells. You can't go wrong with 12 cells (1200 watt peaks, 7 cells=700watt peaks).
There are a few reasons why I’d like to stay with 7-cells for the time being:
a) The disadvantage of charging two packs every time I want to run
b) My charger set-up (two chargers built for 7-cells gives me more run-time than charge-time by cycling my GP’s – gotta scoop up some IB38’s)
c) I've made my own 3+4 saddle packs for weight distribution and organised my chassis layout accordingly
d) The added weight
Certainly, at some point (to my wife’s dismay!), I’ll be going higher voltage, and when I do I plan on going LiPo to maintain the single pack/light truck ‘model’. But for now, as long as I’m on the NiMh’s, my preference would be to gear down if necessary to stick with 7-cells and take the hit on the top-end. As I mentioned earlier, I’m not disappointed with the performance of the SS5800 on 7-cells (for the time-being), I do however realize that I’m out of room and would like to have a system that could run on 7-cells now (at least as well as the SS) and can take higher voltage LiPo in the future.
If there’s nothing out there that I can scale by changing the motor/esc now and upgrading to LiPo in the future.. then I’ll just gear down a little more, throw a fan on the esc and change my driving habits; until I can make the jump to LiPo and new motor/esc at the same time.
btw, Welcome to the Forum! This is The place for BL Maxx info
Welcome to the forum!
Thanks! :D
JimmyT
:cool:
