GorillaMaxx360
GorillaMaxx360's Avatar
01.03.2008, 01:26 PM
lincpimp I believe you are right I use the same setup on my maxx only with the mip cvds. It has the same problem with spacing, but because I am racing my maxx and I am running it just a tad higher than bones level it rests inside the cup perfect. If I extended the arms fully they would fall out, but since I run them bones level they are fine. I also have the adapters mike sells but have not used them, but it seems if i did it would fix the problem because the mip outdrives are longer and should fix the problem. I just don't feel like rebuilding the diff for the 5 time and it works for my application.
