Serum
Serum's Avatar
02.19.2005, 04:15 AM
Yes, i know what you mean, BK says that.
Lipomax means that you don't need to use the TOTAL length of the bar, because the solder also can travel the energy. (so from solder to solder point will be less then the total bar length)
SOldering the batteries toghether with a T-head, will make you a stick-pack, it means that the battery-poles are soldered DIRECTLY on each other.
If you take a look at Candyman's MAXXbling, you can see he also uses side by side batteries. Ryan on this forum also used side by side batts.
