08.22.2005, 08:48 PM
First of all, welcome to the forums!
I agree with the rest on this topic(more voltage is better), but we can certainly set you up with a suiotabel combo to meet your needs in the meantime!
It is a little tricky, though, as the ideal motor for 7 cell operation will be less ideal on higher voltage. If/when you finally decide to make the jump to higher voltage, how high will you go(voltage?) This will have an impact on a setup recommendation. Also, if light weight is your model, do you mind sharing ome specs? I am a light weight fan myself and have a pretty sporty 11.1 volt e-maxx setup myself!
