Thread: 4 pole motors
sikeston34m
sikeston34m's Avatar
01.04.2008, 03:22 AM
Originally Posted by BP-Revo View Post
Apparently, machine winding is not as tight/precise as hand winding. This makes sense as because while a machine will just go around and around that pole to a set number of winds, hand winding can more precisely lay each wind down, and if there is a mistake (like a kink in the wire that throws off a certain wind), it can be redone.
This may be true for most regular conventional armature winds for brushed motors, and probably even outrunner motors.
But in the case of brushless inrunners, I believe these windings are "wound" or laid in a certain pattern, then compressed and baked inside a mold. When it cools, it retains it's shape so it will fit inside the motor can.
