01.04.2008, 11:52 PM
I believe I enter the right info
Differential Ratio: 3.307
Transmission Ratio: 1.16
Other Ratio: 1
Spur Tooth Count: 65
Pinion Tooth Count: 22
Total Voltage: 7.5
Motor KV: 3500
Tire Diameter (inches): 5.75
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 2.95 : 1
Total Ratio: 11.33399 : 1
Tire Circumference (inches): 18.06 inches (458.83mm)
Total Motor Speed: 26250 RPM
Vehicle Speed: 39.62 MPH (63.64km/h)
Effective Speed Rate: 5.28mph/V (8.49kmh/V)
Effective KV Value: 3500
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
