MetalMan
MetalMan's Avatar
08.23.2005, 11:17 AM
Gustav, you have a good idea with that. (an extended bearing thingy). To me, that seems like somethat that could only be made on a lathe. It would require a large nut too! (~3/8"). So basically, all that is needed is a back plate for a differential that would have an extended bearing mount, that would be cut on a lathe. I will try to design this piece on Solidworks.
