david lamontagn
01.05.2008, 10:17 AM
Originally Posted by ssspconcepts View Post
Hey Wildman,
My settings are the default settings, except I switched to 5 Lipo for the battery setting. I will tell you this...unbeknownst to me...when I plugged into the USB interface, the software automatically returned my controller to default settings...to include setting it back to 2-pole motor mode. This took me about an hour to figure out why the controller wouldn't work after I checked my settings. I went thru the initial setup about four or five times and the controller would just sit there and beep. Well, I went back to the USB and noticed that it was in 2-pole motor mode-bingo. I set it back to 4-pole mode (for Neu motors are 4-pole motors) and went back thru the setup procedure and everything works fine now--whew!!!!!! Quite a scare I had there. You can see the video of my maiden run if you goto my picasa link http://picasaweb.google.com/ssspconc...36201234213570
Wow!!!! this CRT is a BOMB And very clean looking job bude But seem to have pretty bad cogging on start??
Can you tell me the weight of your truck in RTR mode please?
Thank you!!!!!!!
