jhautz
jhautz's Avatar
01.05.2008, 08:22 PM
if the temps you posted are in C then that is on the hot side. You might consider gearing down a couple teeth on the pinion.
If the temps posted are Fahrenheit then you have no problem.
What ESC, motor and batteries are you running? Also what vehicle and what pinion/spur gearing are you using. You haven given much info so far.
to make it...
or break it...
Silent...But Deadly
