Thread
T maxx hv conversion
6
01.05.2008, 10:43 PM
Just finished installing the rear diff. Not really diffincult, just time consuming. The pics below should give you an idea of how it was done. Had to cut the pvc coupler to the correct lenght and press it into the bulk by hand. When you have the size correct, enlarge the inside diameter to fit the aftershock diff case. Also make sure that a revo driveshaft can fit thru the outside with some slack, as it will sit inside the pvc slightly. Then when it is in there trim the excess that sticks out flush with the bulk. You will have to cut the notch that is used for access to the driveshaft pin, but it is easy with a hobby knife. The front support has to be ground out on the inside to fit the nose of the aftershock diff case. And it will have to be notched to clear the diff case screws. Lots of test fitting involved, but I did it right the first time, with no redos.
Alot of Savage parts for sale!!!
Find all posts by lincpimp
