I also use the 989 and that same battery (TrueRC 8000mAH 4s pack). However, I use the Hyperion LBA10 balancer, and I always balance while charging. 16 volts is fine.... at the end of the charge, the battery should be 16.8V. Here is how mine is hooked up if it helps at all:
