sikeston34m
sikeston34m's Avatar
01.05.2008, 11:56 PM
Keep up the good work Linc!
I may be following in your footsteps on this one really soon.
What gear ratio are those diffs? If I recall correctly, they use the 43 tooth spur and are 1/8 size.
Will the spiral 43 tooth ring and 10 tooth pinion fit these?
Looks like a 8mm pinion shaft with 6mm output shafts.
