Originally Posted by jnev
I actually just bought a new MM ESC (2 days ago) for my RC10GT  . So should I just plug in my 4s pack and see if it works? Unfortunately I do not have any 7 cell packs to make 14 cells.... I also wanted to run 2s through it for my GT, and was planning to keep the internal BEC. Could I still try 4s for a couple minutes just to see if it works? Or does the external BEC really have to be wired in?
Make sure you use the external BEC on 4S. I don't see what the problem should be with 4S as long as you use the external BEC, that's what I do with mine. How do you tell which version you have? Mine's fairly new and I'd like to check it out.
