01.06.2008, 01:10 PM
It mat be a "good" battery, but 15C and 4000mAh is only 60A continuous. You should shoot for something like 100-140A continuous for that motor. You didn't mention what gearing you were using - that can make a difference if you lower it a bit. Are you using the two speed, or single speed mod? That can make a large difference as well.
