MM programing problems
renny
if you build it.... Then I can break it
renny's Avatar
MM programing problems - 01.06.2008, 08:19 PM
Im having a problem with programing and heat with my NEW MM.
First things first my setup
REVO truck
mamba max esc
mamba 7700Kv motor
ubec
two 3700Mah 2S 7.4 volt lipo packs wired in parallel with deans ultra plugs
Emax trans. (stock gearing)
When I first had everything wired and ready for first calibration process I double checked all soldering and wire routing to make sure everything was good to go.
OK power up....
It powered up, made a little musical note and then started flashing ALL THREE LEDS.They didnt stop and there was no other movements.
After searching castle faq. and rc monster forums I tried again but this time I dissconected the ubec.
Rechecked all conections...OK power up.....
I was able to go threw the whole calibration process, hook up to my castle link, and drive the truck.
UNTILL I noticed how hot everything was getting so I shut it down and now im a little hesatent on starting it again and risking melt down.
What am I doing wrong???
Any ideas???
