squeeforever
squeeforever's Avatar
01.06.2008, 11:35 PM
Originally Posted by raptor50 View Post
i hooked up to the PC and set at max. take off. I just went w/ 5S and now its ballastic. It still doesnt wheelie, not even close, but its fast and Now it shifts to 2nd gear. with 4S, it will shift if I hold the wheels up, but when it was running, it wasnt shifting.
Final note, Can I not use the clutch spring inside the clutch?
Tekno specifically states you can run it without the spring. Also, if its not shifting, just adjust it....
