Batfish
Batfish's Avatar
08.23.2005, 09:43 PM
Originally posted by El Jarretto
That sucks man. Get well soon. I think you should shoot for under $500 including li-po's and a charger. (I know you already have a charger and li-po's) This way I can prove to extremely ignorant Patrick that he can convert his MGT for under $500.
I'm not sure who Patrick is, but I can already show how to make this for under $500, provided you can get a roller for $200ish. If you've already got the MGT, you can even do batteries and charger for under $500 (nimh - or a little more for lipo).
I'm using a $195 controller, $80 motor, and a $25 steering servo. If you've already got the servo, you're under $500. You may need to spend a couple hours and $10 at Home Depot to buy an aluminum elbow bar to make your motor mount, but no additional drilling needs to be done (to the chassis) for that.
If you don't convert your tranny like I did you'll need the brake servo. You can lock your tranny in forward and drop the reverse servo regardless (unless you want reverse).
Keep in mind, my conversion is for racing - not for top speed. Chances are that my MGT will not reach more than 30MPH once completed. That's fine with me since I can't get up to that speed on my track anyway :)
For a top speed truck you'll need to spend a bit more on batteries and use a different motor than I use.
Once I get this completed, I'll see about doing a full write-up to making a brushless MGT out of a stock MGT.
And thank you folks for the well-wishes :)
Joe
