GO-RIDE.com
01.07.2008, 07:51 PM
Originally Posted by DrKnow65 View Post
Briang"s motor calculator should tell you good motor possibilities.http://scriptasylum.com/rc_speed/
MM and a fiegao is a popular way to go I've noticed.
I've been loving my MM / Ammo 36-50-2300 / 3S combo, but I run a small track so I wanted to be able to gear from 25-45mph. You would propably want a few more motor rpm's so I'd go more in the 3300-3900KV range. But defer to brians calculator and the guy's who run CRT.5's...
I've been working with Brian's calculator and from what I've read the optimum max rpm for a Feigao L is about 35,000. So it looks like an 8L on 3S would be the best solution. However, I'm still unsure if this will give me more punch than my current 6.5 (5900kv) on 2S? I just don't have any experience with the 3S systems.
E-8ight - Tekin RX8 2000kv/4S
