Originally Posted by BlackedOutREVO
The grey springs are the stock ones.....
Hmmm, something I never thought about with a HV set up, so I guess its just fitting it on the car thats hard huh? A place speedo is cheap, mech brakes is cheap because I have tons of servos, and lipos cost the same, along with the motor
Something to think about
The maxamps 2100 lipos are good to use as they can usually fit on the opposite side to the motor in an 1/8 buggy, 2 5s 2100 packs are longer than a std pack, but about the same weight and cost. Plus you can use a cheaper motor, like a 12xl, or 20l feigao. They work much better than their higher kv cousins.
