01.08.2008, 10:37 PM
heres that i got on the speed calc
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 14
Total Voltage: 14.8
Motor KV: 1770
Tire Diameter (inches): 5.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 3.29 : 1
Total Ratio: 9.35165 : 1
Tire Circumference (inches): 17.28 inches (438.88mm)
Total Motor Speed: 26196 RPM
Vehicle Speed: 45.83 MPH (73.63km/h)
Effective Speed Rate: 3.1mph/V (4.97kmh/V)
Effective KV Value: 1770
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
