bdebde
That's All Folks!
bdebde's Avatar
01.09.2008, 12:41 AM
I knew this was asked, but didn't know where. So I waited and waited . Please find the attached pictures of a 2280 with the bigger connectors installed. After you do it please post pictures so I can do the same to my 2 2240 and 2250.
That picture is of the hi amp version
I would also like to know how they compare to the longer Neus.
Someone else here has soldered wires right into the 3.5mm plugs on a Lehner with no problems. They should be able to take some heat, the solder connections to change the winding configuration is right next to the plugs.
