stum
01.09.2008, 10:24 PM
Made my ESC tray and mounts for the emaxx water resistant radio box
Designed a better bracket for the front of the tranny here (after the fact)
I got tired of waiting for my 7XL and MM ESC so I dropped in the dual Titan and evx-2 (I had a dud evx-2 though so it often stops for no reason.. a new one is on it's way though :))
I got bored yet again, now waiting for my 5mm pinions for my 7XL and MM esc so I ripped my single VXL motor off my Rustler and installed it on my rEvoLt. Geared 68t spur and 19t pinion.. if someone wanted this setup would be better than two titans any day of the year and geared lower say 17t pinion it will still run same top speed as the stock emaxx setup but just a TON more torque as you will see in the video.
Thanks again guys hope this helps someone else out!!!! I know this is quick so if you have any questions fire away...
