Originally Posted by squeeforever
Why on earth would you say that?? The MM is only rated for 4S, yet the older ones can handle up to 5S. Even Castle reps said its good to go on 4S with the right setup, but it was just rated at 3S to cover there asses.
I got that from a few posts in rcgroups. Now I'm saying that from expirience as well as the Mamba seems to overheat easely. I have the new controller with the same set up that I had with the MM and it doesn't even break a sweet. Castle will be like Novak one day.
