01.10.2008, 03:08 PM
Originally Posted by johnrobholmes View Post
I have heard of guys plugging 3s packs into a 12v battery to charge them. Let the heat hit around 150F and they are done. Takes 10min or less.
Yeah, I've heard of that too. If it's the same thing I'm thinking of, they rely on the resistance of a long piece of wire to limit the current somewhat. A VERY poor way to do this. Far too unreliable if someone uses a battery or 12v supply that is higher or lower in voltage, or uses different size packs. It would be easy (and safer IMO) to make a simple and proper 10-20A constant-current circuit and just use a temp probe to stop the charge at a certain temp.
