01.10.2008, 05:07 PM
Originally Posted by ICUBoy View Post
Great idea using that motor, but it would only work if you use true four wheel drive.
One motor per corner, 4 ESCs and 12S LiPo. Should get well over 12 mph. Good luck and please post photos of it a. leaving the ground; and b. leaving Earth orbit.
I was only going to do 2wd, for greater stability and weight distribution. I have a feeling that if I go with 4 of these things that I may need to step up to 16s. I wonder if maxamps could make me a pair of 8s 10000 packs. That way I could move them around the chassis till I get the balance correct.
I am not sure if I have a camera that has good enough resolution to show the cen leaving orbit, maybe if I paint the body yellow it will show up.
