01.10.2008, 10:19 PM
Originally Posted by Revracer View Post
i was going to run a ubec. but will the 8l be as quick as the 7xl? i mean will it have the same acceleration and everything as the 7xl? and a 16/40 is way different from stock. stock is 18/38. but wit ha 16/40 it will still do around 35? will it be able to handle 4s once i step up to that?
You will not find a motor that will work well on 3s and 4s. You want the motor speed of a feigao to be around 35k rpm. Much more and it will get too hot. Much less and your gearing will be too high and the motor will heat up due to increaded load. The 8l will easily pull wheelies, and we geared it for 40 mph and it ran fine, just a little warmer than the 40/16 gearing. On 4s the 7xl will be a beast, but 3s will not spin the motor fast enough.
