01.10.2008, 10:50 PM
Originally Posted by Revracer View Post
and your saying 35-40mph with wheelies easily? and then if i did want to step up i could go to something like a 9 or 10l and be safe on 4s?
If you keep the 2 speed and mech brakes I do not see a problem running a 10l on 4s. The 7xl will provide more power than the 10l will on 4s. However the 7xl will require better batteries than the 10l will. It is a balancing act picking a motor, you need to take into consideration the battery and gearing.
What 3s battery do you plan on running?
