New 3905 E maxx AXI Outrunner setup
sikeston34m
sikeston34m's Avatar
New 3905 E maxx AXI Outrunner setup - 01.11.2008, 03:14 PM
Just call me the outrunner motor man. LOL I guess I'm a little obsessed with them. They are very powerful, very efficient, and present a new challenge in gearing and configuration. I like it.
With this setup, we're using the factory Revo style slipper and mod 1 gears.
Motor choice is an AXI 2826/10 with the fan added. The AXI is spinning one of Mike's 22 tooth Mod 1 Pinions. The 5mm Motor shaft length is 20mm so it goes all the way to the end of the pinion. Perfect and tough!
Spur choice is a Nitro Revo 40 tooth Mod 1. It fits the slipper, afterall it is patterned after the Revo.
The ESC is a Monster Pro 125 amp modded with a Novak 2700uf Cap. It's hard to see in the picture, but it's secured to the rear shock tower.
I added a fan over the ESC just in case we need it when it comes to 6S setups and higher gearing. This is powered by the BEC. Power for this is picked up at the Receiver.
There is a CC BEC there that has been turned up to 6 volts. This makes the steering stronger and more responsive.
She just had her first run. I love it. It's a torque monster. It will flip on it's lid from a standing stop if it's getting good traction.
I played with the slipper some. Too loose isn't good for acceleration and too tight defeats it's purpose. I backed it off where I knew it was too loose, then tightened it, trying it each time in 1/4 turn increments. It will slip under a big drivetrain shock with how it is set now.
Can't wait until the 2 speed kit is released. Running this is like running in 1st gear. Loads of Torque, but only about 28-30mph top speed. 2nd gear should push this over 40mph.
The motor isn't struggling or loaded at all. WOT from a standstill or any speed is fine. This doesn't cog at all.
I love how efficient this is. Warmest the motor got might have been 90 degrees. The ESC was cold. Lipo's were cold.
First run on 4S 5000mah Lipo lasted 38 minutes!
Check this out.
