Thread: MM Cogging Help
01.12.2008, 12:54 AM
Ok, raise the start power to medium and see if that helps. What gearing are you using. On 3s in a truggy you will get maybe 30 mph, 25mph would be safer, but the gearing will be super high, thus very hard on the motor and esc on startup. 4s is better, but 5s would be ideal, however the mm may not like 5s. I would gear for about 35mph on 4s and then play with the start power. Also check your motor to esc connection, and hardwire if possible. If you are using 4mm connectors, they may be the source of the cogging. Use 5mm or larger connectors, or just hardwire. It cures alot of problems when you hardwire, plus it is one less area to be concerned with.
