squeeforever
squeeforever's Avatar
01.12.2008, 02:40 PM
Just file down the shaft. Another member said he just hooked it up and had it at a low RPM and took a file to it. Said it took a while, but worked. Or, if you drill out, or have all your pinions made with a 6mm bore, just get a bore reducer from Mike. He'll hook you up.
