Thread
Modded Mamba Max Testing!!
2
GriffinRU
01.12.2008, 05:22 PM
Originally Posted by
DrKnow65
Just resurected mustbnitro's dead MM
Long story short, the solder from one of the caps was touching one of the buss leads. It actually had 12 burnt fet's and 2 that were cracked from taking the heat sink off. It has a few lifted traces and 3 of the copper sleeves that interconnect the pcb were pulled out so it took a little creative soldering.
I didn't keep the mod though, didn't want to spend the time if it wasn't going to work and I'm not taking it apart again to try. So at this point it just has the better caps, diode, and deans wet noodle wire. Think I'll attach a fan and call it good.
You can do it
Nowadays broken Mamba's on eBay have some value...
GriffinRU
Find all posts by GriffinRU
