CRT.5 Brushless Truggy
phatmonk
RC carbon junkie
phatmonk's Avatar
CRT.5 Brushless Truggy - 01.12.2008, 05:41 PM
I have started to convert my CRT.5 to brushless I ordered a motor mount from rcmonster and I need some advice on what motor/esc,Pinion pitch and inside diameter of pinion of course that depends on the motor.I picked up a BCE chassis that enables the use of a fullsize steering servo only to find out that the end of the servo is going to be real close to the end of the motor pinion gear I think I can make it work it should have about 5mm clearance.I would like to keep the BCE chassis its a nice machined aluminum chassis that included a machined topplate and radiotray.And like a dummy I didnt check the clearance until I cut the BCE radio chassis.Heres a picture
